Measurement Studio for VB6
visual basic code problem
Hello!
I want to use visual basic to build a htm which can control labview throght datasocket, i set the switch
as " Swithc until release " in visual basic, the code is
Private Sub CWButton1_Click()
CWDataSocket1.Data = CWButton1.Value
End Sub
but the led of labview can't light on.
is the code problem?
thanks!
(2,970 Views)
The problem is most likely because you have the code in the Click() event handler. The click event in VB is a left mouse down AND mouse up over the controls. If you are wanting it to send out the value when you press and hold the button down, change the event handler to the ValueChanged event.
Best Regards,
Chris Matthews
(2,970 Views)
