Measurement Studio for VB6
visual basic graphic two voltage signals? how can i do it??
I'm new with VB so please can anyone help me with this simple programm?? how can i graphic two signals in VB???
(8,857 Views)
Hi Angelx999!
I have some questions for you before i send you any program. What version of VB are you using? Are you using any hardware? Do you have the needed drivers installed along with VB?
Let me know what hardware you are using and ill help you with your program.
Best regards!
(8,851 Views)
I used VB version 6, I also have  the needed drivers for the ports, I used an input wire IIIE STD 488 port, do you think that I have to install the Labview tools (CWGraph?) or how can I do it? please help me!!
(8,842 Views)
Please help me!!! I used the VB version 6, all I want is the programm for the graphic!!! but not with the labview buttons (CWgraph for example), using for example the MSchart function or picture but please help me at least with the programm!!!!!!!
(8,816 Views)
Hi angelx999, sorry about my delay in the answer.
Do you have any of the NI products, hardware or software?
Im asking this because the driver for DAQ installs several examples about how to do this. I dont understand why dont you want to use the components if they are there already. Anyway ill work on seeing if i create a simple program example on how to do this and ill let you know.
Take care
(8,772 Views)
Hello dear,
I am also using VB 6 for programming and having NI 9172 chassis with NI 9205 DAQ card.
I am facing similar kind of problem for displaying the graph using picture or ms graph. While trying for contiuously plotting the graph,
my pc get hanged.
You may please send me some sample code in VB so as to display graph continuously.
You may plz reply at the earliest.
Thanks & regards
Darshan
Email- darsh_c852000@yahoo.com
-+91-265-3048026
(8,091 Views)
