Measurement Studio for VB6
why i do get an offset with analog input
Hello Mr.O,
Regarding the concept I will refer to a communication book. But according to the Labview signal express, if we arre receiving a voltage signal and add a power spectrum step next to the signal acquisition in Signal Express. What is the parameter it is displaying on the y axis which is labled as db rms ref 1.0E+0 V/ sqrt(hz) ?
My question is how it will calculate power without knowing resistance and current values ????????
Message 21 of 24
(4,575 Views)
The power will be calculated using the input resistance of your device. If you are using a simmulated signal probably it is using a 1 ohm resistor as a reference.
Mr.O
Message 22 of 24
(4,572 Views)
In my case I am measuring voltage across resistor of 54 ohms. Sine wave across resistor is given from signal generator. My daq 6361 input impedence is  10 G.ohms.
Which resistance signal express is considering ??? DAQ input impedence or the resistance across which I am measuring voltage ?????
Thanks and regards
Vaidhin.
Message 23 of 24
(4,568 Views)
Then you are meassuring the power with the 54 ohm for sure!
Mr.O
Message 24 of 24
(4,565 Views)
