Measurement Studio for VC++
2 second delay
squidmixer,
I do not have a BNC 2110 readily available at the moment, and I still was a bit confused about the configuration windows, however I wrote the attached code so I could see see exactly what is going on (it looks kind of complicated, but when running, it is much clearer).  The code writes a full buffer before starting generation/acquisition and then writes a half buffer each write. The data being written is directly displayed on the front panel.  The read reads a half buffer of data and displays it directly.  Due to the fact we wrote a full buffers worth of data initially, the minimum delay between the measurement and generation displays we would expect is 2 iterations (2 half-buffers, the amount of data we wrote before starting the tasks):
The only things you have to input are your device channels and the regeneration setting.  I reccomend using the internal routing so you don't have to wire anything (e.g. Dev1/_ao0_vs_aognd for the input and Dev1/ao0 for the output). You can then change the amplitude of the signal while the program is running.
However, if we allow regeneration, then we end up with longer than we expect for reasons discussed earlier.  On my M Series card (a PCI-6251), I see 2 half buffers without regeneration and 4 with. My E Series (a 6024E) shows 2 half buffers no matter which regeneration setting.
If you would give this a try, if you see the same behavior I did, we may have to start looking elsewhere for the cause of the delay. I wouldn't worry too much about posting to the wrong forum.  If you really want to, you can create another thread and post a link to this one (as well as a link here to that one).
Message Edited by Neal M on 12-10-2007 05:51 PM
Neal M.
Applications Engineering       National Instruments        www.ni.com/support
Message 11 of 11
(1,342 Views)
