Measurement Studio for VC++
200077 error when using DAQmxCfgDigEdgeStartTrig
Hello!
I am using a 6052E card with DAQmx.
When I add the DAQmxCfgDigEdgeStartTrig function to my code to start data collection on a start trigger, I get the error:
-200077
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Here is the code block that I am using this function in:
	char startTrigger[256]="Dev1/PFI0";
	int startEdge=0;//rising edge
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0, Dev1/ai1","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
	DAQmxErrChk (DAQmxCfgDigEdgeStartTrig(taskHandle, startTrigger, startEdge));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,NULL,nFrequency,DAQmx_Val_Rising,DAQmx_Val_ContSamps, (m_nBufferSize*2)));
	DAQmxErrChk (DAQmxStartTask(taskHandle));
Any ideas what I may be doing wrong?
Thanks!
(4,847 Views)
Hi Senkyoshi,
Do you have any other configurartion for the task that you haven't displayed?
Also, can try adding a leading forward slash to your stratTrigger string: "/Dev1/PFI0"
Kyle S.
http://www.ni.com/support
(4,832 Views)
Thanks for the reply ks30,
I do not have any other configuration for the task.
Also, adding a leading forward slash did not change the outcome. Still recieveing the same error.
-senkyoshi
(4,827 Views)
Hi Senkyoshi,
Can you set your startEdge value to DAQmx_Val_Rising instead of 0?
I replicated your issue by doing the opposite so that should resolve it for you.
Kyle S.
(4,798 Views)
So I found the answer to my problem.
I changed "Dev1/PFI0" for start trigger to just "PFI0".
Strange that this would solve the issue.
 to:
char startTrigger[256]="PFI0";
(4,718 Views)
