Measurement Studio for VC++
20MHz timebase
Hello?
I have a question about 20MHz timebase of AI operation on PCI-6025E card.
DAQmxCfgSampClkTiming(taskHandle,"",fdat.trace_size,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,fdat.trace_size)
fdat.trace_size is 1200 and this is a finite sampling repeated by a working tread. I wonder if I'm using 20MHz timebase. Whenever I use 20MHz time base as the second parameter, it returns error saying that I have to change fdat.trace_size to 20,000,000. But if I changed it to 20000000, it says its maximum value is not 20000000, but about 6000000.
How can I use 20MHz timebase?
I'm converting DAQ to DAQmx..from Parkoz.com
(6,208 Views)
Hey,
You can either use "OnboardClock" or can use "100kHzTimebase" as you are acquiring about 1200 samples at 1.2KHz.
Good Luck,
-Lab
(6,194 Views)
