Measurement Studio for VC++
3D
Hello Guys.
I'm trying to find a sample for measurment studio 2010 where I can see how I can do a 3D graph. Is there somewhere a sample for measurment studio 2010?
There are few 3D samples for older version for 32 bit that do not work in windows 7 64 bit. So I'm looking a current sample for this new version of measurment studio
Thanks in advance.
MCZ
(6,666 Views)
Accepted by topic author mcz
Measurement Studio 2010 is not shipped with 3D graphs. You can still use the activeX controls in visual studio 2010, but you will have to add them to the Toolbox view.  To do this:
  1. Right click in the toolbox and select add items from the context menu
  2. in the COM tab, find and select the CW3Dgraph control
  3. The control will now appear in the toolbox, and can be placed on your form.
Hope this helps!
Alexandra
(6,659 Views)
In addition, if you are using Visual C++, you may need to get legacy support for Measurement Studio, if you haven't already. See the instructions here.
(6,657 Views)
Thanks Alexandra. It worked perfect.
(6,637 Views)
