Measurement Studio for VC++
6533 online buffer write
my application requires sending data to all 4 ports of a DIO 32HS at a 2MHz rate, for an undefined length of time.
preparing a bit less than the maximum buffer size (about 64MB /4 it seems) and setting the Buffer control to "reserve", i then begin to send information in arrays of 4 words to the "buffer Write", while cycling trough the buffer. after some initial buffer loading time ( about a second worth of timed output), i begin the output operation with DIO start.
my data being prepared online, i cant use a double buffer configuration (half buffer size being recreated and reloaded), because my application typically stop creating output words in the middle of such half buffer size, leaving the rest of the array full of null values, affecting my output applications.
However "Buffer write" reallocate memory each time a 4-bytes array is sent to it. therefore sending out 10ms worth of data takes 500ms, sending 100ms takes 5seconds!! this makes it impossible to actually prepare online the data to be sent out. by preparing the full length array in advance, the windows limitation of ~16Mwords then limits my output application to max ~8 seconds only.
Is there any way to avoid memory reallocation on calling the Buffer Write? what are actually the elements the dll requires?
i am using traditional NI-DAQ and Labview 7.1.
using a C++ pointer to memory this is easy to setup such an application trough dig_block_out, but then i would need to rewrite the whole prog in C++ (at least the full subroutine)
Thanks for any help on the subject.
... And here's where I keep assorted lengths of wires...
(6,472 Views)
Hello!
Here an example how to re-use the allocated buffer:
http://zone.ni.com/devzone/cda/epd/p/id/3761
Best regards
Ken
(6,452 Views)
Hello Ken,
thanks for this interresting example. however this is not the problem i refer to. if you look at the code i shared, you see that i allocate memory in advance for the generation, and only want to write into it a predefined position inside. the problem is the realocation of windows memory for every control of the "buffer write" subvi or dll, each time it is called.
in C++ i have a pointer to this allocated memory, therefore i just update the value of data. this allows me to write to the buffer in chunks of 4 words faster than the 2MHz output generation. in labiew however, i am obligated to send data in much bigger chunks of about 100ms worth each, in order to keep up with the 2MHz generation.
you can see my test code for DAQmx in this method in this forum:
Best regards
Gabriel
(6,450 Views)
