Measurement Studio for VC++
A question about CWGraph
I'm trying to use CWGraph ActiveX in my MFC project.
I'm using the CWGraph demo bundled with NI-DAQmx 7.5
and my VC++ is still the version 6.
I want to plot a slow varying signal (temperature)
so I was thinking to use a VC++ timer and update the plot
every two seconds.
Was wondering how I can pass the float64 value
(got from DAQmxReadAnalogScalarF64)to CWGraph.
I looked at "Getting started" PDF but I did't understand
(seems that I have to pase an array instead of a scalar).
Thanks in advance.
(3,830 Views)
If you look in your ...\National Instruments\Measurement Studio\VC\Examples\UI\Graph  folder, you can find examples that show how to work with the CNiGraph class.
AlessioD
(3,756 Views)
Transform float64 to double, then user SafeArrayCreate create a safearray, and pass the pointer of safearray to a _variant_t.
pass the _variant_t to CWGraph->Plots->Item(1L)->PlotXY(or PlotX, or PlotXvsY)...
(3,746 Views)
