Measurement Studio for VC++
ANSI C capturing samples from a NI-DAQmx continuously
Good morning to the forum,
I plugged a sinusoidal signal generator to my NI-DAQmx analog to digital board and I would develop an ansi-c application to read at regular intervals ( every x ms ) the sample of every channel ( the board has 32 channels )
I would have a help with this if possible
Thank you very much
Best Regards,
Franco
(3,070 Views)
Hi Francoamato,
I found this link where you can find the information to start working with Text based programming and NI-Daqmx.
Regards.
(3,042 Views)
