Measurement Studio for VC++
ANSI C shipping examples for the NI-DAQmx C API are installed
ANSI C shipping examples for the NI-DAQmx C API are installed as part of the language support and are available under Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C.
I can not locate the examples
I did install the software and
Program Files\National Instruments\NI-DAQ\ does exist but no examples
(8,305 Views)
I found the examples under C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C.
What C program was used to create the dsp and dsw so I know which compiler to purchase
(8,294 Views)
Hi asterof,
I am not sure exactly which examples you are referring to in the ANSI C directory (dsp,dsw), but I believe that all of the examples were written in Visual C++ 6. Along with the C code, each example contains a Visual C++ 6 Project file and a Visual C++ 6 Workspace file.
Keep me posted if you have additional questions.
Message Edited by Jordan D on 04-16-2008 12:52 PM
Jordan D
Applications Engineering
(8,288 Views)
will they compile ok using Microsoft Visual C++ 2005 Express  ?
I have the software, but I have not installed it, wanted to be sure it would before
I install.
(8,283 Views)
Hi Asterof,
I am not sure if the workspace or project files are compatible with Visual C++ 2005 Express but the C source code should be fine. It was written in ANSI C which should be compatible with the majority of the C compilers on the market.
Jordan D
(8,275 Views)
