Measurement Studio for VC++
Access CNiGraph from worker thread?
I am trying to plot my data in my worker thread. I did as follows (I also attaching an example project), but I got run time error.
I am using Measurement Studio 6.0 and Visual Studio 6.0 SP#5.
I read some answers on this problem. Maybe, CoInitialize() is hint. However, I cannot understand how to use this function. How I can access?
Please read my example:
UINT ThreadProc(LPVOID lParam);
BOOL CMyThreadDlg::OnInitDialog()
CDialog::OnInitDialog();
// Add "About..." menu item to system menu.
// TODO: Add extra initialization here
AfxBeginThread(ThreadProc,(LPVOID)this);
return TRUE; // return TRUE unless you set the focus to a control
C
MyThreadDlg* pDlg = (CMyThreadDlg*)lParam;
CNiReal64Vector tData;
CNiMath::SineWave(tData,200,1.0);
pDlg->m_graph.PlotY(tData);
return (UINT)0;
(3,385 Views)
I believe you are correct about CoInitialize being the problem. To see what error you are actually getting, change your code as follows:
CoInitialize(NULL);
try
CMyThreadDlg* pDlg = (CMyThreadDlg*)lParam;
catch (CException *e)
e->ReportError();
e->Delete();
CoUnitialize();
return (UINT)0;
You should see a MessageBox that tells you that you probably need to call CoInitialize(). To do that, change your code as follows:
try
e->ReportError();
e->Delete();
return (UINT)0;
(3,385 Views)
