Measurement Studio for VC++
Adding CW++ tools to Visual C++(cont)
Thanks for the tip Tony. I used the dialog test switch on a dialog with a CW++ control and it previews nicely. When I run the program and hit the button to display that dialog nothing happens. It's as if the button has no function attached to it. If I remove the CW++ control and run the program again the dialog is displayed.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(3,554 Views)
Problem solved. Had to set up ActiveX by including the line:
AfxEnableControlContainer();
in the InitInstance function in the Application class.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(3,554 Views)
