Measurement Studio for VC++
Annotation placement help with Z-order
Hello Everyone,
I am using the NiGraph activex control to plot a few sets of data. At certain points I want to mark a circular area that represents a range around a point, so that the user can easily see if the data falls in that range. Well, I have set an annotation at that point as a solid circle point type shape, which works fine. My problem is that when the plots are drawn they are under my annotation shape. I need to have the plot draw over the annotation. I can't find anything to adjust this. I am not sure if the annotation is the best way to accomplish what I want, so if anyone can help me with a fix or another suggestion is it greatly appreciated!
Thanks in advance.
(3,384 Views)
Have you tried setting the fill property to none?
Steve
(3,378 Views)
For anyone that is interested I talked to support about this issue and they advised that I use extra plots to draw the circles.
(3,375 Views)
