Measurement Studio for VC++
Annotations.Add very slow Visual C++
I need to add lots of annotations on my graph. The problem is the time for adding all the annotatios is too big. From what i have observed the time for a
for ( i = 0 ; i < MAX_COUNT ; i++ ) niGraph.Annotations.Add ( )
depends on MAX_COUNT ^ 2. Is there any workaround to the problem? I really need the annotations.
Thank you,
Mircea
(3,417 Views)
Hello
I guess I dont really know how many annotations you are planning to add, but you might want to consider adding them during design time. Adding several hundred annotations programatically will take a little time, since you are creating annotation objects on the fly and adding them to the graph.
Bilal Durrani
NI
Bilal Durrani
NI
(3,417 Views)
Hello
I have to add a maximum of 2000 annotations and unfortunately i can't add them staticaly. And adding them dynamically takes just too long ( a few minutes ) I was thinking about drawing them but i don't know how to draw on the same plot lines that are not connected like 1 1 for example. Please tell me how can I do that ( if I can ) If I draw everything on a new plot than I have the same problem ( i would add 2000 plots not 2000 annotations ).
PS I was wondering why adding an annotation is dependent on the annotation number. Are all the other annotations redrawn ?
Thank you for your time
Mircea Mateica
(3,417 Views)
An annotation is not just a drawing on the graph, everytime you add an annotation, you are actaully creating a CWAnnotation object, each with its own methods and properties. Having 2000 plots probably wont change things either, since you will have created 2000 CWPlot objects.
Bilal
Bilal Durrani
NI
(3,417 Views)
