Measurement Studio for VC++
Are dashed grid lines possible without bitmap background?
I am trying to get dashed grid lines onto my graph.  Having searched around, I suspect that I can only achieve this by setting the background as a bitmap that has the dashed lines on.  Is this correct?
I think that this was addressed in the .NET version, which now has this functionality, but not in the (legacy) VC++ version.  I just wanted to confirm that this was the case.
(7,048 Views)
Hi DeltaC,
Could you tell me the exact versions of the measurement studio and visual studio you're using that aren't allowing you this functionality?
Kind regards,
Matt H
National Instruments UK
(6,991 Views)
Hi Matt,
Thanks for the reply.  I'm using version 12.0.0.318.  The option doesn't appear to be in the property pages.
EDIT: I'm using Visual Studio 2010 version 10.0.30319.1.
(6,989 Views)
Actually, the version of MStudio I listed is the one I originally installed, but that didn't come with VC++ or MFC support, so I requested the C++ MFC Legacy Support R2 for Visual Studio 2010 and installed it afterwards.
The About box in the graph property pages says version 8.6.11 Release (465) (602).
(6,968 Views)
Accepted by topic author RichardHHHHHHHH
Hi Richard,
After installing the legacy support version to one of our machines I can confirm that the feature you're looking for does not seem not available for VC++. Unfortunately as this is legacy support it is unlikely the feature will be added in the future.
I hope this answers your question
Kind regards,
Matt H
(6,963 Views)
That's what I suspected.
Thanks, Matt.
(6,959 Views)
