Measurement Studio for VC++
AttachControlSite not working
I have attached CWGraph control into my dialog, created member variable pointer with the same class and then try to get the object with AttachControlSite(this, IDC_GRAPH1). Since I could not get the handle with:
CNiGraph graph;
graph.AttachControlSite(this, IDC_GRAPH1); // this resulted in graph being NULL
I tried this:
CNiGraph* p_graph;
p_graph = (CNiGraph*)GetDlgItem(IDC_GRAPH1); // CWnd is NULL, but I'm getting NI::CNiControl with this call and CWnd is part of it
p_graph->AttachControlSite(this, IDC_GRAPH1); // This doesn't change anything
This call fails naturally since CWnd is not initialized:
m_pCalGraph->PlotXY(fr, (dPwrLvl*-1) - 10);
"Unhandled exception at 0x78244515 (mfc80d.dll) in foo.exe: 0xC0000005: Access violation reading location 0x0000009c."
In afxstate.cpp where pNewState in NULL.
    if (AfxGetAmbientActCtx() &&
        pNewState->m_hActCtx != INVALID_HANDLE_VALUE)
(7,077 Views)
Hi Sami71,
Please see if you are having the same issue as discussed in this thread:
http://forums.ni.com/ni/board/message?board.id=231&message.id=3138&requireLogin=False
What version of Measurement Studio are you using?
Gavin Fox
Systems Software
(7,058 Views)
8.1.0.256
I have been able to create the control with
    m_CalGraph.Create("", WS_VISIBLE, wr, this, IDC_CWGRAPH2, NULL, false);
but it would be nice if I could just get the handle for it from the existing graph from dialog. This doesn't seem to work either:
    DDX_Control(pDX,
IDC_CWGRAPH2, m_CalGraph);
I did make the mistake of using the Visual Studio wrapper instead of using the Measurement Studio toolbar.
(7,048 Views)
Seems like the dynamic Create() gives me another problem, it seems to embed the "Evalution Version" on distributed EXE's Graph. Now I need to figure out how to statically create the control in Dialog editor, which BTW does not give me the option to "Add Variable..."
(6,960 Views)
I think I got it solved.
(6,952 Views)
Hi Sami71,
It sounds like you already got the issue taken care of, but just in case, check out the
How Do I Create Controls Dynamically in Microsoft Visual C++ When Using MFC without the Demo Mode Me... KnowledgeBase.
Hope this helps!
Best Regards,
Jonathan N.
(6,940 Views)
