Measurement Studio for VC++
C++ Worker Thread - Quit Task
I have an installation of DAQmx on Linux with an 6221 PCI card. My software contains a C++ class which contains a worker thread.
I setup a digital read using various functions from DAQmx and then DAQmxReadDigitalLines. This works in a simplistic way and either quits with an error code (becuase no IO changes have accurred), or if I set WaitInfinitely returns from the function with a number of samples.
So thus far all works OK.The problem I have if I want to quit cleanly with this functionaility in a worker thread.
I have a worker thread so the class interface can be accessed by a statemachine without being blocked or having to wait. I plan to have 2 other threads containing tasks collecting and writing analogue samples.
The problem Im facing is if I 'WaitInfinitely', (so the thread is blocked by DAQmxReadDigitalLines waiting for a change to occurr) and call DAQmxStopTask from an object member (with the unit32 task handle), I get a segmentation error and the task doesnt quit.
I could go down the route of checking a continue flag every loop of the a finite timeout instead of WaitInfinitely, but I have made an exception class DAQmxErrChk so its awkard and besides, surely the best method is to have the task waiting for a change and to be able to stop it. I dont want to miss any in handling the timeout durations ever few seconds!
I dont want to forcefull quit the thread as that may leave DAQmx in a bad state.
Surely there is a method to gracefully quit blocking tasks?
(6,452 Views)
Ive also tried DAQmxTaskControl(task, DAQmx_Val_Task_Abort) and DAQmxTaskControl(task, DAQmx_Val_Task_Stop);
This also just gives a "Segmentation fault".
Is this becuase youre not supposed to interrupt DAQmxReadDigitalLines() when DAQmx_Val_WaitInfinitely is set?
The problem is I need to monitor certain lines in the background and verify that they dont change BUT also need to quit whenever the user wants and allow this by software.
(6,451 Views)
ok Ive found this:
http://digital.ni.com/public.nsf/websearch/EB202A78FB1D083186257117005CEF21?OpenDocument
Ive tried the GCC flag, and linking -ldl as the first library but I still get a segmentation fault if I try to use any of the calls to end the task early.
Smiley Mad
(6,446 Views)
OK, it was the number of samples and the buffer id supplied. The task inside a thread, controlled from the outside is now working as expected 🙂
(6,434 Views)
