Measurement Studio for VC++
C sample to send CAM Message via Xnet and USB-8502 device
We have an USB-8502 with one CAN port. We are using it to communicate with an automobile ECU. We can successfully send and receive messages using NI-XNET Bus Monitor.
Now we need to make a C application to exchange custom CAN messages with the ECU via the USB-8502. Could you please help us with an sample code ?
NI Certified LabVIEW Associate Developer
(4,911 Views)
Accepted by topic author Lahcen27
Hi Lahcen27,
You can find C examples in the XNET driver folders following this file path: C:\Users\Public\Documents\National Instruments\NI-XNET\Examples\MS Visual C\CAN >> then choose an appropriate example for your application.
More information about the XNET C examples can be found here:
Getting Started - NI-XNET 16.0 Help
http://zone.ni.com/reference/en-XX/help/372841M-01/nixnet/gettingstarted_c/
Thanks!
Erika
Technical Support Engineer
(4,870 Views)
Hi Erika,
Thank you for your reply.
OK I'll see the forlder.
The link you sent cannot be open. I get the " Page Error" message. But I searched for "Getting Started - NI-XNET 16.0 Help"  in the search bar, then I found the the right page. Thanks !
Best regards
Lahcen
(4,867 Views)
