Measurement Studio for VC++
CIN compiling error as following!!
I have add the command in projiect seting like"C:\Program Files\National Instruments\LabVIEW 6.1\cintools\ $(TargetName)-d $(WkspDir)\$(OutDir)" and "
$(OutDir)$(TargetName).lsb",but still get the error! What should i do??
--------------------Configuration: VI_name - Win32 Debug--------------------
Performing Custom Build Step on .\Debug\VI_name.dll
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
Error executing c:\winnt\system32\cmd.exe.
VI_name.dll - 1 error(s), 0 warning(s)
(3,013 Views)
You need quotes around paths that contain spaces. This is true whenever you specify paths to cmd (regardless of whether cmd is run from Visual Studio or from a command prompt).
David Rohacek
(3,013 Views)
