Measurement Studio for VC++
CNiGraph3D and CNiCursor3D problem
I'm using cursors on a CNiGraph3D and my X and Y axes have inverted ranges. The cursor draws in the correct location, but the 'grab' hotspot (where the mouse pointer changes to a hand) is where it would be if the axes were not inverted. Is there a solution, workaround or a fix for this?
(2,957 Views)
Hello
This problem has been reported already. We're looking into correcting this for future releases of Measurement Studio. At this point though, the only way to get around this problem is to make sure you know where the hot spot is before the graph is inverted and use that area, as click and drag will still be valid at that point.
Sorry about the inconvienice this is causing you, but we hope to get this problem fixed ASAP.
Bilal Durrani
NI
Bilal Durrani
NI
(2,957 Views)
