Measurement Studio for VC++
CNiMath::GetPulseParameter()
Dear all,
Please refer to the excel plot for this 1Vpp data running at 250KS/s, 100Hz & 10K sample size.  The ffg table is the derived measurements from the GetPulseParameters().
The amplitude, top & base parameters are quite correct assuming that the unit is in Volt.  However,  I see that the polarity is different.
The delay & width are both incorrect.  I expect the width to be @5ms.
It is also not clear if the measurements were based on 1 period or the whole data.  Moreovver, I doubled the sample size at 20K
and the measurements were different.  Why ?  Thanks!!!
Message 1 of 1
(6,268 Views)
