Measurement Studio for VC++
CNiTimer OnEvent function
I use CNiTimer in CDialog class with CNiButton:
// .h
CMyDialog : public CDialog
public:
CNiTimer* pTimer;
CNiButton m_btnRed;
public:
//constructor,destructor,initdialog functions...
void OnEventTimer(CNitimer &timer);
// .cpp
void CMyDialog :: OnEventTimer(CNitimer &timer)
m_btnRed.EnableWindow(TRUE); --> OK
m_btnRed.SetValue(true); --> CNiOleError !!
When OnEventTimer is executing, "m_btnRed.SetValue" generate an error ?
Thanks.
(3,539 Views)
If you catch the exception and display the message, I suspect that you will see that CoInitialize has not been called from the thread. The timer calls your OnEventTimer from a worker thread. Because the Measurement Studio user interface controls are ActiveX controls, you must initialize COM from each thread that calls into them. Call CoInitialize or CoInitializeEx at the beginning of OnEventTimer to fix this problem.
(3,524 Views)
