Measurement Studio for VC++
CNiTimer and threads?
If I derive a class from CNiTimer to handle the OnEvent method then the documentaion says this will run in a system thread. My question is: If I derive say 8 classes from CNiTimer will these run in 8 seperate system threads. I don't see these threads in the Task manager.
(4,065 Views)
There is only 1 timer thread per process. CNiTimer uses the Windows multimedia timer, which is limited to a single instance per process. See
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/multimed/mmtime_4msz.asp
for more information on Windows multimedia timers.
(4,065 Views)
Thanks for the answer, but that is just not true.
On Win9X there are 32 multimedia timers for the entire system and I can't find any limitation on per-process use. On WinNT each process can have up to 16 multimedia timers. I don't know the specs for W2K and above, but I would use a queue timer.
As I suspected this is a limitation of the NI timer, so I wont use it.
(4,065 Views)
I stand corrected. I had misinterpretted some internal documentation.
You are correct that 1 timer thread per process is an implementation limitation of the CNiTimer class.
David Rohacek
(4,065 Views)
Thanks for the help
(4,065 Views)
