Measurement Studio for VC++
CNiVisaSession::Read() Serial asynchrone, is it possible?
System: Measurement Studio 6.0
We want to use Serial with VISA in asynchrone mode (with handler if possible). We have made a small program (based on CDialog) to test it, but every time we call CNiVisaSession::Read(,,jobID) (jobID for asynchrone mode!), it returns VisaSuccessIoSync, why? (what conditions are missing; event queue in place of handler; or serial VISA cannot be asynchrone at all?)
In fact, we want that CNiVisaSession::Read() returns immediately and uses asynchrone mode (actually, it blocks).
We use the following code (in class CMyClass):
Header:
class CMyClass: public CDialog
ViByte m_nSerialBuffer[255];
CNiVisaJobId m_nSerialJobId;
CNiVisaSession m_nSerialSession;
void InitNIVisaSerial();
ViStatus OnNIVisaEvent(CNiVisaEvent& nEvent);
Body:
CMyClass():m_nSerialSession("ASRL1::INSTR", VisaExclusiveLock){}
void CMyClass::InitNIVisaSerial()// called from OnInitDialog
// initialize serial
m_nSerialSession.SetAttribute(VisaSerialBaudRate, (uInt32)9600);
m_nSerialSession.SetAttribute(VisaSerialParity, VisaParityNone);
m_nSerialSession.SetAttribute(VisaSerialDataBits, (uInt16)8);
m_nSerialSession.SetAttribute(VisaSerialStopBits, VisaStopOne);
m_nSerialSession.SetAttribute(VisaSerialFlowControl, VisaFlowNone);
m_nSerialSession.SetAttribute(VisaTimeout, (uInt16)5000); //time out of 5 secs
try {
// we want the 0x0D character termination
m_nSerialSession.SetAttribute(VisaSerialEndIn, VisaEndTermChar);
m_nSerialSession.SetAttribute(VisaTerminationChar, (uInt8)0x0D);
// OnNIVisaEvent is called on completion,ok
CNiVisaEventHandlerId nID;
m_nSerialSession.InstallEventHandler(VisaEventIoComplete, *this,
OnVisaEventHandler(CMyClass, OnNIVisaEvent),
nID);
m_nSerialSession.EnableEvent(VisaEventIoComplete, VisaHandler);
catch (CNiVisaException* e)
e->ReportError();
e->Delete ();
// called from Read button
void CMyClass::OnReadBtn()
// here we send asynchrone read, but every time
// the command complete in synchrone mode, for which raison?
ViStatus nStatus = m_nSerialSession.Read(m_nSerialBuffer, 255, m_nSerialJobId);
if(nStatus == VisaSuccessIoSync) // go always in this condtion after timeout
AfxMessageBox("Reading synchrone");
Thanks a lot,
Alain
(3,365 Views)
Alain:
NI-VISA performs asynchronous I/O differently based on the bus type and whether you are using the queue or the handler. For Serial, to make the callbacks work efficiently, there is a threshold level that you need to set in MAX. Go to the Tools menu and choose the VISA options. Set the Minimum Async Transfer to a smaller number of bytes (probably 250) and then try your application again. It should now do the I/O in another thread, and that is the thread where your callback should occur. You can verify this in NI Spy.
Dan Mondrik
Senior Software Engineer, NI-VISA
(3,365 Views)
