Measurement Studio for VC++
Calling NI objects from aa Afx thread
I have a Dialog class in Visual c++ 2003 "TESTDlg.h and TestDlg.cpp"
In TestDlg.h i have publikc members:
public:
   CNiButton m_nbool1;
    CNiButton m_nbool2;
    CNiButton m_nbool3;
    CNiButton m_nbool4;
    CNiButton m_nbool5;
in TestDlg.cpp i have a worker thread: CWinThread* pThread = AfxBeginThread( MyFunc_, this, THREAD_PRIORITY_NORMAL, 0, 0,NULL);
MyFunc function gets the "this" pointer and obtains a reference to the Dialog.
I can access all the Public members within TestDlg but the NIButtons(although they are also public)
My code returns with error:
Unhandled exception at 0x7c812a5b in TestDlg.exe: Microsoft C++ exception: NI::CNiOleException @ 0x01bafb54.
How can i fix that?
(8,245 Views)
Lachezar,
Could you post a small example that demonstrate this behavior?
Song D
Application Engineer
National Instrument
Song Du
Systems Software
National Instruments R&D
(8,220 Views)
It is fixed now.I had to use :
//Main Worker Thread
UINT TestDlg::WorkerThread(LPVOID pParam)
 ::CoInitialize(NULL) ;//NI construct to allow controls from a Thread-Iput in the very beginning
//My code here
     ::CoUninitialize(); //NI construct to allow controls from a Thread - put this at the end of the thread
That fixed it!
(8,199 Views)
I realise that this is some time ago, but I'm working on a similar project and need some MFC assistance.
I've created a DLL with MFC, but I need to use Multithreading to collect some data.
Since all the calls look similar to
_declspec(dllexport) HRESULT __cdecl OpenPort ( unsigned char DeviceID )
 return ( m_pBrickInput->OpenDevice ( DeviceID ) );
I haven't had any reason to create any instances of the class.
Now, when I try to do this...
static void StartRead(void)
 CBrickApp *MyApp;
  MyApp = new (CBrickApp);
  MyApp->StartReader();
void CBrickApp::StartReader(void)
CWinThread  *pReaderThread;
//  this->Data.SetSize(0);
  pReaderThread = AfxBeginThread (ReadThread, (void *)this, THREAD_PRIORITY_HIGHEST,
          0, 0, NULL );
the MFC Linker complains...
Any suggestions ?
DOK
(7,517 Views)
DOK has created a new forum post with this question. See this link for additional resources.
Measurement Studio for VC++ (http://forums.ni.com/ni/board/message?board.id=231&message.id=6360&jump=true#M6360)
Steven Zittrower
http://www.ni.com/support
(7,504 Views)
