Measurement Studio for VC++
Can I have installed the 5.5 and 6.0 versions at the same PC?
Hi to all,
I had the LabWindows 5.5 version installed at my PC.
When I got the 6.0 version I installed it without uninstalling the 5.5 one.
I reinstalled NI-DAQ and I think I installed CVI support and it was installed in the directory on CVI 6.0 because I can run and compile ok with the 6.0 version the projects created with the previous one.
But, when I launch LabWindows 5.5, it doesn't have the DAQ libraries (Ni-DAQ) actives, and I can't compile the projects that uses it.
I have tried to reinstall NI-DAQ in the directory on CVI 5.5, but this operation remove the installation on CVI 6.0.
This is my question: Can I have installed the 5.5 and 6.0 versions of LabWindows installed at the same PC, using
the same NI-DAQ library?
Note: I don't want to run both versions of LabWindows at the same time: I want to have the posibility to decide within both versions each time.
Thanks a lot,
silmarba
(3,668 Views)
Try posting this question on the LabWindows/CVI forum - you'll get a better answer there than in the Measurement Studio for VC++ forum. Thanks.
- Elton
(3,668 Views)
Read the following KnowledgeBase entry off of ni.com and follow Option 2. You will need to copy the dataacq.* files from one of your CVI installations' \bin directory to the other's.
http://digital.ni.com/public.nsf/websearch/07CDFC21381CD725862569C9007EC8FE?OpenDocument
Jason F.
www.ni.com/ask
(3,668 Views)
Thanks a lot Jason,
It was just all I need.
I copied the dataacq.* files at CVI 5.5 directories and it worked very well.
silmarba.
PD: I am sorry because I post my question at Visual C++ place instead of LabWindows one.
(3,668 Views)
Hi Elton,
I am sorry for my slip.
silmarba
(3,668 Views)
