Measurement Studio for VC++
Can i use C Code at Compact Vision or Compact Rio?
hi,
i have a very important question!!
can i use the C code that the Vision Assistant generates, in the compact vision system, even in DLL form??? if yes, how can i download it to the compact vison?
can i use C code at the compact rio?
greets,
gerald
(3,383 Views)
You can use C-Code on Realtime targets (Such as C-Rio or a Compact Vision system) as long as you compile a DLL out of it, and call this DLL from LabView. Take care that no Windows-Specific things are in the dll (MFC, ActiveX, Windows SDK etc.).
As you always need LabView, to use the dll, it would be better to create a LabView VI from the Vision Assistant, and download this VI to your Compact Vision System.
(3,366 Views)
