Measurement Studio for VC++
Can plot axes be adjusted on a plot that is filled with data?
When trying to programmatically set the max and min values for a graph axis, I find that I have to clear the plots first or the new values will not take effect. Am I missing something here? It seems that you should be able to set axes parameters when the graph buffer is filled or empty.
Thanks in advance.
Wayne
(2,861 Views)
I'd have to see some code to see what's going on in your case. I created a new project, added a graph to the dialog, added a member variable for the graph called m_graph, and the following code works for me:
// Plot some data.
CNiReal64Vector data;
CNiMath::SineWave(data, 100, 1.0);
m_graph.PlotY(data);
// Set the values min and max values of the graph axis.
m_graph.Axes.Item(1).SetMinMax(0, 200);
Please try this and see how it works. If this doesn't address your problem, please post some sample code that demonstrates your problem. Hope this helps.
- Elton
(2,861 Views)
