Measurement Studio for VC++
Can someone tell me why this code doesn't run?
I downloaded the attached VC++ project from this web site, it compiles, but doesn't run (it dies inCDialog::DoModal). I think that it has something to do with the fact that the three display ActiveX controls can't be instantiated. Do I need to register them or something? Can anyone help?
Thanks.
(3,602 Views)
Those activeX controls are installed and registered with IMAQ Vision software. I just opened it in my computer and it worked fine.
Yusuf C.
Applications Engineering
(3,602 Views)
Thanks for looking at that for me.
Imaq vision is installed on my computer...i even uninstalled and reinstalled. When i open the VC++ app it gives me three errors that say "an activex control cannont be instantiated". I wonder how i can fix this problem.
(3,602 Views)
Does it tell you which ActiveX control?
(3,602 Views)
Well, i'm pretty sure that it is IDC_CWIMAQVIEWER1, IDC_CWIMAQVIEWER2, and IDC_CWIMAQVISION1 because when I open the the .rc file those three controls are just blue boxes with "ActiveX" printed in the middle of them. I figured that if they were instantiated correctly then they would show as controls. The application builds and links, but when the application runs, the domodal() call returns 0 and the application closes.
Also, None of the IMAQ Vision ActiveX controls show up in the "Insert Component and Controls" dialog in the VC++ IDE. Do you think Measurement Studio needs to be reinstalled??
(3,602 Views)
Well, everything worked after reinstalling imaq2.6 and measurement studio.
Thanks.
(3,602 Views)
