Measurement Studio for VC++
Cannot find nicanmsc.lib
Hello folks,
I hope I'm posting this in the correct forum.
I'm developing a CAN (NICAN) program in C++ using MS Visual Studio 2008.  I have found the nican.h, but I haven't been able to find nicanmsc.lib.
Any assistance is greatly appreciated.
Chris Hassan
(7,934 Views)
Accepted by topic author chassan
Chris,
Check out C:\Program Files\National Instruments\NI-CAN\MS Visual C
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(7,909 Views)
I think I had to check "NI-CAN" when installing/changing labview to get the "NI-CAN" directory.
I tried using the file in an x64 .c program in MSVS and get a bunch of link errors.
Win32 platform mode work ok, but I have java x64 bin and I think I will need x64 bit nicanmsc.lib to
be able to do JNI on a 64 bit java with c and JNI and java.
(6,628 Views)
here are the error I got when trying to build a x64 bit "c" program with nicanmsc.lib
error LNK2019: unresolved external symbol ncCloseObject referenced in function main	C:\Users\...\can.obj	CAN
error LNK2019: unresolved external symbol ncConfig referenced in function main	C:\Users\...\can.obj	CAN
error LNK2019: unresolved external symbol ncOpenObject referenced in function main	C:\Users\...\can.obj	CAN
error LNK2019: unresolved external symbol ncReadMult referenced in function main	C:\...\can.obj	CAN
error LNK2019: unresolved external symbol ncStatusToString referenced in function PrintStat	C:\Users\...\can.obj	CAN
error LNK1120: 5 unresolved externals	C:\Users\...\x64\Debug\CAN.dll	1	1	CAN
(6,626 Views)
Attached is a picture of the NI-CAN that has the nicanmsc.lib
The NI-CAN is in:
National Instruments Device Drivers Disk
Then in the tree:
Communication Buses and Protocols
   NI-CAN 2.7.5
      etc...
I think you need to check this in order to get the nicanmsc.lib
Maybe you also need to check
the
      LabVIEW 2013 (32-bit) Support
         Examples
      Microsoft Visual C Support
         Examples
(6,621 Views)
