Measurement Studio for VC++
CniPicture and IPictureDisp
I am getting compilation error when trying to create CNiPicture from a IPictureDisp pointer. Appreciate example code showing how to use transform CBitmap to CNiPicture. Thanx.
(4,071 Views)
I'm using the GDI+ (Visual Studio 2003 and higher) CImage class to load a bitmap. But once you have the handle to a valid bitmap, try the following
    CImage image;
    HRESULT hr = image.Load("c:\\rotatetest.bmp");
    if(SUCCEEDED(hr))
        PICTDESC pictDesc;
        memset(&pictDesc, 0, sizeof(pictDesc));
        pictDesc.cbSizeofstruct = sizeof(pictDesc);
        pictDesc.picType = PICTYPE_BITMAP;
        pictDesc.bmp.hbitmap = (HBITMAP)image;
        image.Detach();
        CComPtr<IPictureDisp> picture;
        hr = OleCreatePictureIndirect(&pictDesc, IID_IPictureDisp, TRUE, (void**)&picture);
        if (SUCCEEDED(hr))
            CNiPicture pic(picture.Detach(), true);
            m_graph.Annotations.Item(1).Shape.Image.Picture = pic;
I hope this helps
Bilal Durrani
NI
(4,055 Views)
