Measurement Studio for VC++
Configure Slave Triggering
Hi everyone,
I'd like to configure two NI PXI-4204 devices (one as master and one as slave) so that these two devices measure a bunch of samples.
Therefore I've exported the start trigger signal from the master device and set an trigger on this signal for the slave device.
Actually both devices are connected to a frequency generator.
When I'm looking at the measured values I got two data arrays that are NOT synchron.
  TaskHandle  thMaster = NULL;
  TaskHandle  thSlave  = NULL;
  double      masterData[SamplesPerChannel*ChannelMax];
  double      slaveData[SamplesPerChannel];
  long        readMasterData = 0;
  long        readSlaveData = 0;
  long        err  = 0;
if(!err) err = DAQmxCreateTask ( "Master", &thMaster ); if(!err) err = DAQmxCreateAIVoltageChan ( thMaster, "PXI1Slot7/ai0", "", DAQmx_Val_Cfg_Default, 0, 20, DAQmx_Val_Volts, NULL ); if(!err) err = DAQmxCfgSampClkTiming ( thMaster, "", SampleRate, DAQmx_Val_Rising, DAQmx_Val_ContSamps, SamplesPerChannel ); if(!err) err = DAQmxExportSignal ( thMaster, DAQmx_Val_StartTrigger, "PXI_Trig0"); if(!err) err = DAQmxTaskControl ( thMaster, DAQmx_Val_Task_Verify ); if(!err) err = DAQmxCreateTask ( "Slave", &thSlave ); if(!err) err = DAQmxCreateAIVoltageChan ( thSlave , "PXI1Slot8/ai0", "", DAQmx_Val_Cfg_Default, 0, 20, DAQmx_Val_Volts, NULL ); if(!err) err = DAQmxCfgSampClkTiming ( thSlave , "", SampleRate, DAQmx_Val_Rising, DAQmx_Val_ContSamps, SamplesPerChannel ); if(!err) err = DAQmxCfgDigEdgeStartTrig ( thSlave , "/PXI1Slot7/PXI_Trig0", DAQmx_Val_Rising);
if(!err) err = DAQmxTaskControl ( thSlave, DAQmx_Val_Task_Verify ); if(!err) err = DAQmxStartTask ( thSlave ); if(!err) err = DAQmxStartTask ( thMaster ); if(!err) err = DAQmxReadAnalogF64 ( thMaster, SamplesPerChannel, 3.0, DAQmx_Val_GroupByChannel, &masterData[0], sizeof(masterData), &readMasterData, NULL ); if(!err) err = DAQmxReadAnalogF64 ( thSlave , SamplesPerChannel, 3.0, DAQmx_Val_GroupByChannel, &slaveData[0], sizeof(slaveData), &readSlaveData, NULL );
Can anyone point out my mistake within the posted code?
Matthias
(5,574 Views)
which delay is between the values? Do you see an only one value shifted delay?
Have you tried to export the 10 MHz backplane clock?
(5,457 Views)
