Measurement Studio for VC++
Showing results forย
Search instead forย
Did you mean:ย
Continuous reading (width measure) with high frequency
Hi, everyone! At first, I work in VC++ with DAQPad-6020E. I have to process PWM signal in continuous mode with high sample rate (T=10ms Fr=100Hz). After all advices I began used General-Purpose CTR set of functions (ND_BUFFERED_PULSE_WIDTH_MSR) with double buffer. But it works not correct => I received data not with sample rate 100Hz. I receive only 25values/second!!!
I think that it's problem of double buffer. Maybe It cannot work with high frequency? But 100Hz isn't high, isn't it? ๐Ÿ™‚
Can U advice me where is my problem? Maybe there is other methods to process signal? Can U send me example (c++ better;)
And another. I tried read data from DInput by Line and Port functions in the loop. => every i
teration take 4ms!!! I don't understand how read more frequently?
Sorry, my runglish ๐Ÿ™‚
P.S. I set source ND_INTERNAL_100_KHZ, PWM input connect to ND_COUNTER_0 (PFI9)
I collect all information in file...
(3,087 Views)
Hello;
Please see
http://exchange.ni.com/servlet/Redirect?id=8505067
Regards
Filipe A.
(3,087 Views)
