Measurement Studio for VC++
Converting Traditional to NIDAQmx C++ Code
I am trying to upgrade my C++ code from Traditional to NIDAQmx, and I am having hard time finding equivalent terms between the 2 drivers at times, but here is the hardware configuration and the NIDAQmx code I have. Can any one let me know if this is the right code and provide suggestions if possible?  (for 16-MIO E series boards)
- I would like to use an Encoder hooked to PFI7 as external Sampling Clock source (Ctr0)
- I would like to use PFI4 as Once Per Revolution Counter (Ctr1)
- I have 8 Analog Channels
- I need Buffered Edge Counting and continuous sampling
- I expect to read 48000 S/s per channel and 384,000 S/s per 8 channels and this is within range of the advertised 500,000 S/s
SamplingRate = 500,000/NumberOfChannels;
//////////PFI7 - Ctr0
DAQmxErrChk(pDAQmxCreateCICountEdgesChan(m_taskHandle,"Dev1/ctr1","Time Counter",DAQmx_Val_Falling,Initial_Count,DAQmx_Val_CountUp));
DAQmxErrChk(pDAQmxSetCICountEdgesTerm(m_taskHandle,"Dev1/Ctr1","/Dev1/20MHzTimebase");
DAQmxErrChk(pDAQmxCfgSampClkTiming(m_taskHandle,"/Dev1/PFI7",Rate,DAQmx_Val_Falling,DAQmx_Val_ContSamps,m_NIBufferSize/NumberOfChannels)); // using PFI7
 DAQmxErrChk(pDAQmxStartTask(m_taskHandle));
////////////PFI4 – Ctr1
 DAQmxErrChk(pDAQmxCreateCICountEdgesChan(m_taskHandle1,"Dev1/ctr0","Revolution Counter",DAQmx_Val_Falling,Initial_Count,DAQmx_Val_CountUp));
DAQmxErrChk(pDAQmxSetCICountEdgesTerm(m_taskHandle1,"Dev1/Ctr0","/Dev1/20MHzTimebase");
DAQmxErrChk(pDAQmxCfgSampClkTiming(m_taskHandle1,"/Dev1/PFI4",Rate,DAQmx_Val_Falling,DAQmx_Val_ContSamps,m_NIRevsToAverage)); // using PFI4
DAQmxErrChk(pDAQmxStartTask(m_taskHandle1));
////////////////// Analog – 2 channels in this case
DAQmxErrChk(pDAQmxCreateAIVoltageChan(m_taskHandle2,"Dev1/ai0:1","Pressure Channels",DAQmx_Val_RSE,m_MinVal,m_MaxVal,DAQmx_Val_Volts,NULL));
DAQmxErrChk(pDAQmxCfgSampClkTiming(m_taskHandle2,"/Dev1/PFI7",Rate,DAQmx_Val_Falling,DAQmx_Val_ContSamps,m_NIBufferSize/m_NIChannelArray.GetSize()));
//DAQmxErrChk(pDAQmxSetChanAttribute(m_taskHandle2,"Dev1/ai0:1",DAQmx_AI_Gain,2));
//DAQmxErrChk(pDAQmxSetAIConvRate(m_taskHandle2,ConvertClock)); // A/D interchannel time scan intervals, 5 usec default
DAQmxErrChk(pDAQmxSetAIConvSrc(m_taskHandle2,ConvertClkTimeBase));
DAQmxErrChk(pDAQmxRegisterEveryNSamplesEvent(m_taskHandle2,DAQmx_Val_Acquired_Into_Buffer,m_NIBufferSize/m_NIChannelArray.GetSize(),0, &CCommunication::EveryNCallback,this));
DAQmxErrChk (pDAQmxCfgInputBuffer(m_taskHandle2,m_BufferSize*2));
DAQmxErrChk(pDAQmxStartTask(m_taskHandle2));
///////////////////////READ////////////
/// Read Analog
pDAQmxReadBinaryI16 (m_taskHandle2,m_NIBufferSize/NumberOfChannels,0.000012, DAQmx_Val_GroupByScanNumber ,HoldBuffer,m_NIBufferSize,&PointsCollected, NULL);
/// Read Counter
pDAQmxReadCounterU32(m_taskHandle,m_NIBufferSize/NumberOfChannels,0.000012,TimeBuffer,m_NIBufferSize,&NumberReadOnTimeCounter,NULL);
pDAQmxReadCounterU32(m_taskHandle1,m_NIBufferSize/NumberOfChannels,0.000012,TimeBuffer,m_NIBufferSize,&NumberReadOnTimeCounter,NULL);
//////////// Stop and Clear Tasks /////////////////
(6,147 Views)
I would recommend you take a look at the example code that ships with the DAQmx driver.  It is located under Start»Programs»National Instruments»DAQ»Text Based Code Support.  There are a lot of good example that show edge counting, analog input, so on and so forth.  The best way to see if the code will work as well is to just run it and see what happens.  I would probably start piecemeal as well, get the encoder working, then analog input, etc.  A cursory glance and comparison with examples looked pretty good to me.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(6,116 Views)
