Measurement Studio for VC++
DAQ PORT
Hi dear;
Please tell on which port(like COM) it is pluged as it pci-card Please tell,normally,on which port this device is pluged.Also tell  how  this device gets like that serial port or parrallel port.
        ajmal
Lead Data Scientist
(4,250 Views)
Hi ajmal,
  • Simply follow the instructions to install the drivers for your device
  • Then power down your computer and plug the board into the appropriate port.  If you are using a PCI card plug it into the PCI port, if using USB then plug it into the USB port, etc.
  • When you reboot the computer the software for the device should install.
  • Once everything is finished installing you can verify that it is working by going to Start > All Programs > National Instruments and open Measurement and Automation Explorer (MAX).  In MAX go to Devices and Interfaces and you should see your device and have the ability to test it to confirm that it works.
Best of luck,
(4,242 Views)
hi sir
i dnot want info about the installation and plug of the daq card actually i want to know  info about the DAQ.For example Modem is connected on the COM1 port of our PC so like this on which port it lies.Is there special port needed for this device or not.As modem gets the data serially so How DAQ gets data serially or .....thanks.....
        ajmal
Lead Data Scientist
(4,238 Views)
ajmal,
Which device are you using?  Is there a product number or anything on the device that you have?
If you want more theory on just how a DAQ device works, then please peruse this site: Introduction to Data Acquisition
(4,223 Views)
hi sir
i m using 6025E DAQ board and taking input from SCU as analog
Lead Data Scientist
(4,216 Views)
Hello ajmal,
The DAQ board doesn't interface with the serial port on the computers.  It plugs into the computer and communicates via the PCI bus.  You do not need a special "port" to communicate with the DAQ device, it should work just fine in any PCI slot on the computer.  The data is transferred from the DAQ board to the computer's memory using the PCI bus protocol, which you don't have to worry about.
In order to connect to the signal you want to measure, you will need a cable to connect to the 68-pin connector on the DAQ board and on the other end of the cable, have some sort of 68-pin accessory to connect your signal to.  The DAQ board will measure the analog voltage of your signals, convert them to a digital representation, and send this value over the PCI bus to the computer memory.  You can than read this value into your development environment.  This transfer of data is all handled by the DAQ driver.
Eric
DE For Life!
(4,201 Views)
