Measurement Studio for VC++
DAQmx Error: Non-buffered hardware-timed operations are not supported for this d evice and Channel Type.
I am new to NI and to data acuasition cards in general. I am trying to put an application togather that would play large audio file using NI9263.
And i am getting the following error.
DAQmx Error: Non-buffered hardware-timed operations are not supported for this device and Channel Type.
Status Code: -201025
Does my hardware support buffering ?
can i use the EveryNSamplesCallbackAO function ?
Any sample code, will be helpful at this time. Thanks.
(7,196 Views)
Hi yma200,
Are you using a USB 9263?  If so, this might be of help:
http://digital.ni.com/public.nsf/allkb/EC1968728E660B288625780700570D06?OpenDocument
If it doesn't help, can you please post the code that you have that is causing your error?
Bogdan Buricea
(7,184 Views)
Thanks for the response, I am using NI USB-9162.
-Thanks
(7,181 Views)
