Measurement Studio for VC++
DAQmx - how does it multithread?
Howdy,
i am using DAQmx in VC++. my question is how does DAQmx run threads? In traditional DAQ, when you perform an acquisition, it runs as a separate parallel process(if i remember right). Is it the same with DAQmx? or does it run tasks as threads within the calling application's process itself?
thanks in advance,
vikram
(6,696 Views)
Here is some information in the following white paper that I thought would be useful to you.
http://zone.ni.com/devzone/conceptd.nsf/webmain/5df09082448cbcf886256e7c0078ee9c
NI-DAQmx driver software is designed to help you significantly improve performance by exploiting the computer processor power and the memory structure of operating systems. NI-DAQmx driver software uses a multithread application structure to maximize computer processor power and implements memory-mapped registers to produce unprecedented concurrent and single-point I/O performance. As a result, you can experience up to 40 times better performance when you perform a concurrent I/O operation and 20 times faster execution speed when you perform a single-point I/O operation.
NI-DAQmx is an innovative driver software architecture that incorporates multithread technology. With multithreaded DAQ operations, you can perform an I/O operation independently in a separate thread. This guarantees faster execution speeds when you perform concurrent operations. Performing a concurrent operation, such as generating a continuous analog output waveform while acquiring a continuous analog input signal, in a single-threaded environment can be extremely challenging and can yield slow performance unless you employ complicated programming and timing techniques. Because NI-DAQmx driver software is multithreaded, it guarantees the simultaneous operation of analog input acquisition and analog output generation by assigning a separate thread to each operation. This eliminates the need to develop a complicated program to create an optimized concurrent operation. You can implement a multithreaded DAQ operation simply by using the NI-DAQmx Library.
Take an example of a synchronized AI/AO operation example program. You do not have to manually allocate separate threads for each analog input and analog output operation. The NI-DAQmx functions allocate the threads automatically. Therefore, with the NI-DAQmx Library, you can develop a multithreaded DAQ application without spending time implementing the details.
Thank you
Nandini Subramaniam
(6,686 Views)
Thanks for the info. i looked up the white paper and it doesn't say whether the threads run in a separate process or within the application's (in which the DAQmx calls are made) process.
The reason i ask is i need my program to be really fast and i am experimenting with thread and process priorities. When using traditional DAQ i cannot increase my application's priority above 'above normal'(i get an error). i am guessing it is because the parallel process in which the acquisition runs doesn't get the time it needs to run. will this occur in DAQmx too?
thanks,
vikram
(6,682 Views)
Hi Vik,
With NI-DAQmx, if you use LabVIEW or a multithreaded C program, multiple threads can access the NI-DAQmx driver at the same time as long as those threads are executing different NI-DAQmx tasks. The driver will create a new thread for each data acqusition task and handle the priority to allow the acquisition to be carried out.
Lesley Y.
(6,665 Views)
and the threads that the driver creates - under which process do they run? a separate 'DAQmx process'or the user's program/application process?
thanks Lesley.
vikram
(6,659 Views)
The thread belongs to the user's process. You can see the list of the threads in your process if you set a breakpoint in your app, break and open up the "Threads" window (Ctrl-Alt-H)
Bilal Durrani
NI
(6,652 Views)
Thanks.
forgot about that option entirely 🙂
vikram
(6,648 Views)
