Measurement Studio for VC++
DAQmxErrChk Error
Hello?
I'm testing this code whether DAQmx finds my legacy PCI-6025E device.
DAQmxErrChk code doesn't work for me.
My code is
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int CTestDialogClass::FindMyDAQLegacyDevice_With_DAQmx()
 int32  error=0;
 char  errBuff[2048]={'\0'};
 char  devNames[256]={'\0'};
 char  testDevName[256]={'\0'};
 // DAQmx Configure Code
 /* It seems that DAQmxGetDevProductType and
  * DAQmxGetSysDevNames function works w/o
  * creating a task.
/* DAQmxErrChk  (DAQmxCreateTask("",&taskHandle));
 DAQmxErrChk  (DAQmxStartTask(taskHandle));
 DAQmxErrChk (DAQmxGetDevProductType("Dev1", testDevName, 256));
 DAQmxErrChk (DAQmxGetSysDevNames(devNames,256));
// DAQmxGetDevProductType("Dev1", testDevName, 256);
// DAQmxGetSysDevNames(devNames,256);
 // DAQmx Start Code
 m_cstringProductName = testDevName;
 m_cstringDeviceName = devNames;
 Error:
  if( DAQmxFailed(error) )
   DAQmxGetExtendedErrorInfo(errBuff,2048);
   AfxMessageBox("DAQmx Error, DAQmx can't find the device", MB_OK,0);
/*  if( taskHandle!= 0 ) {
      DAQmx Stop Code
      DAQmxStopTask(taskHandle);
      DAQmxClearTask(taskHandle);
  return 0;
As you see, I commented out some code to find which line makes an error. Even if I don't use DAQmxErrChk function and DAQmxCreateTask, the GetDevProductType and the DAQmxGetSysDevNames functions STILL works.
I wonder why the GetDevProductType and the DAQmxGetSysDevNames functions are working WITHOUT
I'm converting DAQ to DAQmx..from Parkoz.com
(6,963 Views)
Sorry for double posting. This is automatically done by my IE7. Could you delete this? Thanks.
(6,957 Views)
This post has been answered here.
Ana P
(6,929 Views)
