Measurement Studio for VC++
DAQmxErrChk and Regeneration
I wished to inquire about the DAQmxErrChk function. What is it used for and how can it be used to control regeneration? I have observed the following syntax:
DAQmxErrChk (DAQmxSetWriteAttribute (genTaskHandle, DAQmx_Write_RegenMode, DAQmx_Val_DoNotAllowRegen));
Provided I rename genTaskHandle to my own task name (nitWFM), whould there be anything I would need to do to set DoNotAllowRegeneration? Does it matter how I define the task? Where I observed this code there was the following for task definition:
DAQmxErrChk (DAQmxCreateTask("",&genTaskHandle));
DAQmxErrChk (DAQmxCreateAOVoltageChan (genTaskHandle, channels, "", -10.0, 10.0, DAQmx_Val_Volts, NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming (genTaskHandle, "", rate, DAQmx_Val_Rising, DAQmx_Val_ContSamps,
                                        SAMPLESNB));
In my code the task is defined as such:
std::auto_ptr<CNiDAQmxTask> nitWFM;
nitWFM = std::auto_ptr<CNiDAQmxTask>(new CNiDAQmxTask());
Would defining my task like this enable me to still change the Regenation via the above line?
(5,775 Views)
Accepted by topic author masterron1
masterron1:
The DAQmxErrChk function is used to check the status code when calling DAQmx functions (see example here).
If you'd like to change the regeneration settings, there is a regeneration mode property you can set, called "DAQmxSetWriteRegenMode."
For more info on the regeneration properties, see the NI-DAQmx C Reference Help. You can get to it from your Start Menu in "Programs --> National Instruments --> NI-DAQ --> Text-Based Code Support."
Go to the search tab and enter "Regeneration" to get the full list of topics. The first result should have what you need.
Hope that helps!
Caleb Harris
National Instruments | http://www.ni.com/support
(5,745 Views)
