Measurement Studio for VC++
DAQmxGetDeviceAttribute documentation/help missing
No help, user documentation or example files for DAQmxGetDeviceAttribute are included in the Sep05 C reference help (C:\Program Files\National Instruments\NI-DAQ\Docs\*.chm.) Where I can find documentation for DAQmxGetDeviceAttribute?
(4,127 Views)
Hello northcove,
The function DAQmxGetDeviceAttribute is specific to CVI, which is why it is not listed in the DAQmx C Reference Help.  As stated by Sal in this post, in CVI you choose the device property to get, such as "Device Serial Number" and in ANSI C, the corresponding function would be DAQmxGetDevSerialNum.
Please let us know if you have further questions.
Laura
(4,118 Views)
HI!
  In CVI.....
   DAQmxGetDeviceAttribute prototype:
            int32 DAQmxGetDeviceAttribute (const char Device_Name[], int32 Attribute, void *Value, ...);
   as attribute, you can get the following:
                  - Product type
                  - Device Serial number
                  - Device is simulated
and in NIDAQmx.h:
#define DAQmx_Dev_ProductType            0x0631 // Indicates the product name of the device.
#define DAQmx_Dev_SerialNum                0x0632 // Indicates the serial number of the device. This value is zero if the device does not have a serial number.
#define DAQmx_Dev_IsSimulated              0x22CA // Indicates if the device is a simulated device.
I don't know if this works......
graziano
(4,101 Views)
