Measurement Studio for VC++
DAQmxRegisterEveryNSamplesEvent called again inside the callback
I am wondering if after using  DAQmxRegisterEveryNSamplesEvent to give me a callback at N Samples, I can call again the same function or another without restarting the task to change the number of samples before I receive a new callback.
Alex
(6,417 Views)
Accepted by topic author lourman
Dear laurman
It is recommended to have only one thread per task. You should place your DAQmxRegisterEveryNSamplesEvent in the same thread as your task and callback function. The DAQmx driver is designed to have the task, event and callback all in the same thread. If you have it in a separate thread than your callback will not be able to see this event and be triggered because it is not in the same thread as the task.  In summary,once you call this for your task, you can't define it again without restarting the task.
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
(6,387 Views)
