Measurement Studio for VC++
DAQmxRegisterEveryNSamplesEvent is never called in MFC environment
Hello? I'm uing DAQmx8.9 version with Visual  C++ 6. DAQmxRegisterEveryNSamplesEvent is never called in MFC environment.
Do I have to upgrade to .Net base compiler? I have Visual Studio 2008 and will install this tomorrow to see if this may work in .Net compiler.
I searched this forum and found I was not alone having this issue.
Message Edited by anarkie on 08-05-2009 10:12 AM
I'm converting DAQ to DAQmx..from Parkoz.com
(6,432 Views)
Anarkie,
Thanks for posting on the NI Forums! From some of the documents that I was able to find it appears as though with DAQmx and using MFC you need to use VS 2003/2005/2008 for the best success. I am guessing that the reason you are having these problems is from using VS 6. I have attached the document I found that describes these points in more detail. Thanks!
Programming NI-DAQ in Visual C++ .NET (MFC)
Aaron W.
CLA, CTA and CPI
(6,408 Views)
