Measurement Studio for VC++
DIG_Block_PG_Config 6534 timebase problem
The NI-DAQ documentation say you can use the following values in the DIG_Block_PG_Config function timebase parameter,
-3: 50 ns (653X devices only).
1: 1 µs.
2: 10 µs.
3: 100 µs.
4: 1 ms.
5: 10 ms.
Yet in the 6534 manual it says you set the timebase frequency to = 20MHz, 10MHz, 1MHz, 100kHz, 10kHz, 1kHz or 100Hz. This would appear that there are 7 timebase options supported by the card, but the software only has 6. The 10MHz (100ns) option is not listed in the DIG_Block_PG_Config documentation. I am wondering is the NI-DAQ documentation wrong and missing a value or am I limited to what the function will support.
(3,229 Views)
Yes, this does seem to be inconsistent. Thanks for pointing this out! I'll go ahead and report this. You can still get a 10 MHz transfer rate though by specifying the 20 MHz timbase and using a timebase divisor of 2.
Russell
(3,229 Views)
