Measurement Studio for VC++
DLL Timeout
Hey everyone,
I have a DLL where it's functions are able to run when called from an EXE I create, but not from Labview.
It seems to be timing out at a certain line in the code(When run in Labview), and I was wondering if anyone have any sort of tips on howto fix this - I'm stuck! 😃
-Gene
(3,585 Views)
I suggest posting this question in the LabVIEW forum to get the best answer to this question.
- Elton
(3,585 Views)
I've never heard of a "DLL Timeout"
Is this an error code that the function is returning, or is the DLL locking up and not returning control back to LabVIEW.
Does the DLL have a simpler function that you can test with, or does it only affect a certain function call in LabVIEW?
(3,585 Views)
Hey David,
Thanks for your reply. The DLL is not locking up, the function I am running actually "times out" and will return a error code back to Labview.
I've broken up the DLL into several steps to isolate the issue, it just seems to have a problem with this one line in my code.
Is there any limitations on DLL's created in Labview?
(3,585 Views)
