01-19-2009 05:23 AM
Dear All,
I made a DLL for my application.And When I call this dll from TestStand program I can not reach with my functions paremeters.
There is error on screen:
No Paremeter Information error bar says
This function does not have a paremeter information in the DLL.
I have to adjust the dll functions paremeters.But ı can not do this yet.
Measurement Studio is ver 6.0
There is no error while creating the dll.
Thank you very much
Best Regards,
01-22-2009 11:57 AM
Hi MuratTUNC,
In order for TestStand to recognize the parameters of the function, you need to use a type library with your dll. More information on how to add a type library can be found here:
http://msdn.microsoft.com/en-us/library/aa266425(VS.60).aspx
Let me know if you have any other questions!
01-23-2009 06:21 AM
01-26-2009 09:14 AM
Hi Mura,
The message you are seeing is not an error; it is just warning you that TestStand cannot find the prototype for your dll. To get the prototype, it is necessary to declare the function in the .h file of your dll source in addition to declaring in the c file. If you are still having problems, please let me know, but in the meantime you can manually enter the parameters for the module, and it will work. Hope this helps!
03-10-2009 02:00 AM
Hi ,
I made a labview dll(ver 8.2.1) which is working correctly.I use this dll with testSatnd 2.0.I am calling this dll and I get a correct result for my applications.I can give and take paremeters correctly. I want to see the resultant image on the front panel,but I can not see the front panel of the dll VI.In my application I am sending my color paremeters to the labview dll,and I want to see the color datas image on the User Interface of the dll.I can make image processing things correctly but I can not see the User interface.
Thank you very much,Best Regards,
Murat Tunç
İstanbul Turkey
03-10-2009 04:38 PM
Hi Murat,
Have you tried checking the "show vi front panel when called" in the specify module selection? This should show the front panel of the LabVIEW dll. Let me know if you are still having problems!
