Measurement Studio for VC++
Data acquisition from text file
Hi!
I have the following problem to solve and would like to know if Measurement Studio for VC++ can help:
I would like to read data from a text file with NMEA strings (see example below) and plot them. For instance, the text file contains latitude and longitude values form a GPS which I would like to visualize. Thus, does MS offer an method to read values from a text file, store and plot them?
Here is the example data:
$GAUW1,10072013,102836215,106*10
$GAUW1,10072013,102836315,106*11
$GAEGA,10072013,102836201,12.667,-8.184,125.518,0.35675,0.20416,0.90942,5.0,-2.6,5.6,0.0040,0.0199,-1.0180*52
$GAEGA,10072013,102836301,12.667,-8.272,125.870,0.33264,0.21392,0.88653,4.8,-2.5,5.0,0.0020,0.0269,-1.0120*58
$GAEGA,10072013,102836401,12.722,-8.371,126.265,0.32287,0.21728,0.90942,5.3,-2.1,5.0,0.0009,0.0210,-1.0120*54
$GAUW1,10072013,102836415,106*16
$GAEGA,10072013,102836501,12.799,-8.459,126.639,0.33844,0.22064,0.91339,5.9,-2.0,5.0,0.0040,0.0269,-1.0109*59
$GPGGA,102836.00,5206.3626665,N,02113.7018049,E,5,04,0.9,84.447,M,31.50,M,01,0000*61
$GAUW1,10072013,102836515,108*19
$GPGGA,102836.20,5206.3626252,N,02113.7018318,E,5,04,0.9,84.437,M,31.50,M,00,0000*62
$GPGGA,102836.40,5206.3626250,N,02113.7018294,E,5,04,0.9,84.432,M,31.50,M,00,0000*66
$GAEGA,10072013,102836601,12.875,-8.525,127.001,0.32623,0.22064,0.90942,5.4,-1.9,4.6,0.0080,0.0199,-1.0140*55
$GAUW1,10072013,102836615,108*1A
$GAEGA,10072013,102836701,12.952,-8.602,127.397,0.33264,0.21087,0.89019,5.4,-2.1,5.6,0.0069,0.0230,-1.0149*59
$GAUW1,10072013,102836715,108*1B
$GAEGA,10072013,102836801,13.007,-8.679,127.770,0.32928,0.21392,0.89813,5.6,-2.3,5.1,0.0029,0.0210,-1.0120*56
$GPGGA,102836.60,5206.3626270,N,02113.7018271,E,5,04,0.9,84.428,M,31.50,M,00,0000*66
$GAUW1,10072013,102836815,108*14
$GAEGA,10072013,102836901,13.095,-8.800,128.133,0.34454,0.21057,0.90179,5.1,-2.1,5.3,0.0069,0.0269,-1.0169*55
$GAUW1,10072013,102836915,111*1D
$GAEGA,10072013,102837001,13.084,-8.865,128.462,0.33569,0.21728,0.89416,5.0,-2.0,5.3,0.0000,0.0219,-1.0129*50
$GPGGA,102836.80,5206.3626262,N,02113.7018203,E,5,04,0.9,84.417,M,31.50,M,00,0000*62
$GPZDA,102837.00,10,07,2013,,*6F
$GAUW1,10072013,102837015,111*15
$GAUW1,10072013,102837115,109*1D
$GAUW1,10072013,102837215,109*1E
(6,728 Views)
Hi Julian,
of course it is possible to use Measurment Studio for this application. I did not found any example which solves your task. Did you already start programming? A XY graph is available. The NMEA strings are officially documented. You have to do some parsing work on your own.
In general your question is a Visual C++ topic and not Measurement Studio specific. Perhaps somebody else published the solution on the web. Did you do some research?
Kind Regards,
VanS
(6,682 Views)
Hi Julian,
i am also working on NMEA data and facing the same problem. I have used Marine-api and using netbeansIDE for Testing my java code.  i have extracted the required TalkerIDs and SentenceIDs for obtaining the Position parameters from the received GPS data. Now i want to plot a grid view and show the latitude and longitude point on that Grid.
can you help me regarding this problem.
thank you in advance.
regards,
Shyam Barange
(5,252 Views)
hello JulianHeinz.. have you done with the Visualization part of your work.
(5,151 Views)
