Measurement Studio for VC++
Deployment of a datasocket application
I am using Measurement studios 7 with MS .NET (C++) to develop applications that use the datasocket classes. I use the 'Setup and Deployment Project' wizard to create a setup program. But everytime it finishes installing I run the program and it gives me a runtime error. Note: The program runs perfectly on my development computer. I also ran into the paragraph below in the Measurement Studio 7 read me file. What are the work arounds for this problem?
Known Issues in Measurement Studio 7.0
Redistribution
The DataSocketServer.msm and DataSocketCore.msm merge modules do not work properly with Visual Studio .NET deployment projects. Either use anohter tool to create deployment projects for applications that use DataSocket o
r contact NI Technical Support for help with redistributing DataSocket applications.
(3,034 Views)
Hello
I would recommned contacting an Applications Eng. by using option 2 on the following link
http://www.ni.com/support/
They should be able to help you out from there.
Bilal Durrani
NI
Bilal Durrani
NI
(3,034 Views)
