Measurement Studio for VC++
Device supports sample clock input
I'm trying to find the best way to check if an NI device supports sample clock input. For example, I have a USB-6008 which does not support sample clock input. When I call DAQmxGetDevTerminals, I get "/Dev1/ai/StartTrigger, /Dev1/PFI0". For start trigger capability, I can call DAQmxGetDevAITrigUsage or look in the terminals string for "ai/StartTrigger". Should I search the string for "ai/SampleClock", or is there a function similar to DAQmxGetDevAITrigUsage?
Thank you,
CV
(5,660 Views)
Hey CV,
From what I've seen, I don't know of a function similar to DAQmxGetDevAITrigUsage that works with the sample clock. It sounds like searching the terminal string may be your best bet for achieving the functionality you're looking for.
(5,648 Views)
