Measurement Studio for VC++
Difference between name.lib and nameD.lib
What's the difference between xxxx.lib files and xxxxD.lib files?
(3,380 Views)
The xxxD.lib are debug libraries. When you build an application in debug mode, the application is built with the xxxD.lib library. When you build an application in release mode, the application is built with the xxx.lib library.
- Elton
(3,375 Views)
